1993 Nissan Sentra would Move
1LADYLIKESCARS
  • 1993 NISSAN SENTRA
Transmission problem
1993 Nissan Sentra 4 cyl Front Wheel Drive Manual
bought a 93 nissan old owner said all it needed was a clutch put one in a the car still does not move and the wheels seem to lock up. Please help!
Tuesday, June 9th, 2009 AT 3:28 PM
BILLYMAC
  • 2,204 POSTS
Hi, I assume that you replaced clutch pressure plate and throwout bearing. This could be a bad transmission.
Does the trans feel like it is going into gear. Are the axles good not binding? I know it is a lot of work. But I would remove the axles and see if the trans works. The diff in the trans could be broken. Good luck and if I can help just ask billymac
Tuesday, June 9th, 2009 AT 4:14 PM
