1993 Nissan Sentra studs
PARO_INC
Tires and Wheels problem
1993 Nissan Sentra 4 cyl Front Wheel Drive Manual
What is the procedure in replacing broken studs on my car
Feb 8, 2009 at 3:06 AM
SAWMASTER88
  • 38 POSTS
More than likely you will have to remove the hub assembly. Once it is off, you should be able to use a mallet, or hammer and pound them out. If they are really rusted in I would suggest spraying the studs with PB Blaster. (try to get as little as possible on the bearing itself). Hopefully this will help you, and good luck.
Feb 9, 2009 at 2:30 PM
