1993 Nissan Sentra Repair Slave Cylinder on rear wheel
213,456 MILES • 4 CYL • 2WD • MANUAL
OOMTOM
How do I go about repairing the Brake slave cylinder on the rear wheels.
Jul 14, 2010 at 11:52 PM
  • 75,988 POSTS
You need to pull the drum off to get to the wheel cylinders-in front of the drum you will see 2 holes insert the correct size bolt in it and tighten it this will cause the drum to gradually come out as you turn the bolt
Jul 15, 2010 at 12:01 AM
  • 31,937 POSTS
Hi there,
If the wheel cylinder is leaking the internal seal is damaged. There are two ways to repair the original cylinder, one is to clean and hone out (if cast as you can't hone alloy) and fit an over size seal, or re sleeve and fit a standard seal, (this you won't be able to do yourself) but the cheapest and quickest option is to fit a new cylinder and re bleed the system.
Mark (mhpautos)
Jul 15, 2010 at 12:03 AM
