1993 Nissan Sentra Fuel Gauge dosent work and blower only w
1993 NISSAN SENTRA
19,500 MILES • 4 CYL • FWD • MANUAL
LOSTINFL
I just purchased this car. The gas read half a tank when I started to drive it. I let it get down to 1/4 then I filled it up but the gauge is still at 1/4 can you replace the float in this type car or ido I have to replace the entire fuel pump. Also the blower only works on hi, what do I need to do to fix this also. Thanks
May 1, 2008 at 10:32 AM
For the gauge-inspect the fuel pump/sending unit connector-that don't work replace the sending unit- For the blower check the blower motor resistor.
May 1, 2008 at 10:54 AM
LOSTINFL
the fuel pump was recently replaced would something like a missed connection be the issue or something obvious like that? Thanks for your help
May 1, 2008 at 1:20 PM
Check the connector could be slightly loose you never know-Been here before with these Sentra's. Connection okay change the assembly unit.
May 1, 2008 at 8:42 PM
