1993 Nissan Sentra fuel
LRW
Engine Performance problem
1993 Nissan Sentra 4 cyl Front Wheel Drive Manual
It has a hard time starting. It is like it is not getting
enough fuel. It will not accelerate. If you have it
in fifth gear it will decrease in speed until you are in
frst. The motor will not rev up. Sometimes as you
go through the gears when you shift gears it will
decelerate until you have to down shift.
The clutch also sticks down and you have to put your foot under it and pull it up.
May 5, 2009 at 12:10 PM
MMPRINCE4000
  • 8,548 POSTS
Start with the engine, have the fuel pressure checked with mechanical gauge.
Clutch could be a return spring, or binding at the clutch fork, excessive movement by engine caused by motor mount etc.
May 6, 2009 at 4:16 AM
