1992 Nissan Sentra Will Not Start
ROLANDC
Engine Mechanical problem
1992 Nissan Sentra Front Wheel Drive Automatic 165253 miles
I had to move the gear shift forward or move in while in gear to get it to start. When I turned the key on to start, the dash lights would dim just a little. A month ago I tried to start the car (it started and ran fine the day before) and it would not start neither did the lights dim. I checked the battery and it was ok. I got in it last week to try it and to my surprise it started without any problem. I then tried it four more times and it started ok. On the fifth time, it would not start and the lights did not dim. I thought during the four times that I heard a faint clicking sound but could not be sure. Could this be a relay and if so where would it be located? Thanks!!
Nov 6, 2008 at 9:47 AM
ZACKMAN
  • 4,202 POSTS
If you have to move the shifter to start (being an automatic), that leads me to believe that you have a faulty neutral safety switch or your your shifter cable is out of adjustment.
Nov 6, 2008 at 12:37 PM
ROLANDC
Thanks for the reply. Could you tell me where the neutral safety switch is located and can I bypass it? Also, there appears to be a rod connection to the shifter rather than a cable. Can it be adjusted? Thanks again.
Nov 6, 2008 at 1:27 PM
