AN ACCIDENT CREATED A SMALL CRACK IN BOTTOM OF CAST ALUMINUM TRANS CASE. DO YOU HAVE TO PULL ENGINE TO REPLACE TRANS CASE? OR CAN THIS BE WELDED, PATCHED WITH JB WELD. EVEN HAD A THOUGHT OF DRILLING HOLE AS LARGE AS CRACK AND THEN INSTALLING A SCREW WITH WASHER. YOUR IDEAS PLEASE!
Feb 13, 2008 at 2:29 PM
