Hi I took of the valve cover and im not getting oil to the overhead cams
Monday, November 24th, 2008 AT 7:51 AM
MECHANIC
Check the oil pressure to make sure that the oil pump is working-oil pressure okay could mean a clogged oil galleries
SPONSORED LINKS
Monday, November 24th, 2008 AT 10:32 AM
PORGIE123
MEMBER
For 1992 nissan sentra
Monday, November 24th, 2008 AT 6:37 PM
MECHANIC
The oil pressure should be 7-27psi at idle and at 3K rpms 50-64psi. Oil pump is on the front cover
Monday, November 24th, 2008 AT 7:22 PM
PORGIE123
MEMBER
The last post says oil pump is on the front cover? Is it in the front cover or under it. MY QUESTION IS. IS THERE ACCESS WITHOUT REMOVING FRONT COVER? WHERE CAN I FIND A DIAGRAM?
Monday, November 24th, 2008 AT 7:32 PM
MECHANIC
There's no access to it you have to remove the front timing cover to get to it-
Dunno what you're up to, your problem is you don't have oil in the valve train -but sure seems to be demanding for answers maybe a little cooperation might get you somewhere-Bye
SPONSORED LINKS
Monday, November 24th, 2008 AT 7:38 PM
PORGIE123
MEMBER
I I apologize just cant find the answer where the oil pump is, 3 days now I cant afford to pay for the diagrams or information, and frustration has got the best of me. Im sorry, I wont bother you again. Thanks george
Monday, November 24th, 2008 AT 7:45 PM
MECHANIC
The oil pump is attached to the front cover-see below
Monday, November 24th, 2008 AT 10:23 PM
PORGIE123
MEMBER
Thank you for the oil pump diagram it is very helpful. Now I know where to start. You have made my day. God bless, thank you George
