1992 Nissan Sentra odd brake light problem
140,000 MILES • 4 CYL • FWD • AUTOMATIC
ENDLESSRAYNE
i recently got pulled over for a brake light out, so i replaced the bulb thinking it was all good, even after a state inspection they replaced the bulb again then passed it. however i was told by people that my brake light was out, but when i looked it wasnt. what happens is when i turn my headlights on, my driver side brakelight doesnt work, but when they are off, it works?
Feb 3, 2009 at 6:19 AM
  • 75,988 POSTS
Pull the bulb out and clean the contacts in the socket make sure there's no corrosion between the contacts.
Feb 3, 2009 at 9:04 AM
KHLOW2008
  • 41,812 POSTS
2 cents to add here.
Check the grounding points at rear tailight as well, a bad ground would cause havoc to the circuit as well.
Feb 3, 2009 at 9:17 AM
