1992 Nissan Sentra jerking on acceleration
RDORKO
I have a 1992 Nissan Sentra. I replaced the cap and rotor, plugs and wires about 1 year ago. I recently replaced a fuel injector. There have been no other repairs to the vehicle. When I push on the gas pedal the care sputters a bit and does it when I shift gears, too. It seems to go away after I hit higher RPM's. It doesn't do it while the car is driving.....ONLY when I push the gas pedal. It doesn't stall out at all and it drives like it is on glass. It doesn't to this all the time and there aren't any dash lights on stating there is a problem. What are some things I can check?
Jun 16, 2006 at 3:12 AM
SYNCRAIT
  • 235 POSTS
i would at night with the engine running look under the hood for arcing from the wires....also how recent did you replace the injector?
Jun 16, 2006 at 3:15 AM
RDORKO
Explain what I'm looking for if a wire is "Arching"... I replaced the injector about 5 months ago, but I just put new "o" rings on that injector last weekend because it was leaking gas from the injector.
Jun 16, 2006 at 4:15 AM
SYNCRAIT
  • 235 POSTS
it will look like a little blue flash much like the one the spark plugs make...
Jun 16, 2006 at 4:22 AM
RDORKO
If one of the wires is arching do I replace the plug that goes with that wire or do I replace all the wires?
Could this problem be caused by a bad sensor?
Jun 16, 2006 at 4:28 AM
SYNCRAIT
  • 235 POSTS
well i would replace all the wires just because there fairly cheap but im sure you can get away with just replacing one if you either saved your old ones or can find a place to just buy one not too sure if they sell them in singles...does the engine still jump if its not in gear?
Jun 16, 2006 at 4:33 AM
RDORKO
The problem only exists when I step on the gas.
Jun 16, 2006 at 4:36 AM
