Does the 1990 sentra has drums in the back or just rotors?
Mar 25, 2008 at 9:50 AM
✓ASE Certified Mechanic
Its got drums-to pull it off use to 2 intake manifold bolts from the engine theres 2 small hole that you screw in on the face of the drum- or you go behind the backing plate thru the brake adjuster/star wheel and retract it-
Mar 25, 2008 at 10:03 AM
