1990 Nissan Sentra
JRPORTER23
Engine Mechanical problem
1990 Nissan Sentra 4 cyl Two Wheel Drive Manual
Have a bad alternator on the 1990 Sentra, the engine is a 1988. I can't find a alternator that is good and that will fit. So I want to take the guts out of the bad alternator and replace them. Can you tell me want compatible alternator that I could use.
Jun 10, 2010 at 4:39 AM
BLUELIGHTNIN6
  • 16,542 POSTS
a quick google found several places that you could order a reman alternator from...if you are rebuilding it yourself than parts from a 82 to 88 should work .
Jun 10, 2010 at 4:17 PM
