1989 Nissan Sentra engine shut off
200,000 MILES • 4 CYL • FWD • MANUAL
DIMAANOROLANDO
why does my engine shut off?
i buy new sets of spark plugs and turn out that it was not the problem
Feb 23, 2010 at 4:34 PM
  • 75,988 POSTS
Do below to determine if its a fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Feb 23, 2010 at 8:19 PM
