1989 Nissan Sentra Brake power booster
160,891 MILES • 4 CYL • FWD • AUTOMATIC
MARENA
How do I replace the brake power boster?
Oct 8, 2008 at 5:18 AM
ZACKMAN
  • 4,202 POSTS
Remove all brake fluid from reservoir. Remove brake master cylinder from the booster, should be 2 nuts. From inside the car, remove the booster retaining nuts, I think there 3 of them. Remove the pin attaching the pushrod. Now you can remove the booster.
Make sure that you bleed your brake after you are done.
Mar 13, 2021 at 10:59 AM
