Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Sentra
Engine
Timing Belt
1987 Nissan Sentra TIMING BELT
1987 NISSAN SENTRA
60,000 MILES • 4 CYL • 4WD • MANUAL
GLORIAVAL
MEMBER
1 POST
I NEED A DIAGRAM ON HOW TO SET THE TIMING ON A TIMING BELT FOR A 1987 NISSAN SENTRA 4 CYCLINDER 4 WHEEL DRIVE WITH A MANUAL TRANSMISSION
Feb 27, 2008 at 2:50 PM
Experienced Mechanic
There you go-make sure the no.1 piston is on its compression stroke when you put belt On.
May 23, 2019 at 12:15 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
