firing order
86,000 MILES • 4 CYL • FWD • AUTOMATIC
WALT4523
what is the firing order?
Nov 13, 2009 at 2:21 AM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1231.jpg
Dec 5, 2009 at 2:05 PM
SCOOPTOMMY
My 2004 Nissan Sentra with 1.8 litre engine and 130,000 kms on it is not behaving:( I recently had the cam sensor replaced (twice) but after a week or two it acts up again, sputtering and******** especially in the mornings. Can you help? Thanks
Jul 30, 2019 at 12:03 PM (Merged)
  • 110,248 POSTS
It could deal with a stretched timing belt.
KHLOW2008
  • 41,812 POSTS
Is the Check Engine Light indicating? What was the reason for replacing the cam sensor?
SCOOPTOMMY
Hi There,
The "service engine" light is on, the scan said the cam sensor was the reason so I had it replaced, it was OK for no more than a week or so and the same problem started all over again. I purchased a second cam sensor from the Nissan dealership in my area and the same thing happened???? After the car is running for awhile it works fine, but it takes a while for it to get going. It starts right away but sputters and coughs all over the place. Thanks
SCOOPTOMMY
Hi There, The "Service Engine" light is on, a scan of the engine said the cam sensor was bad so I had it replace, it worked well for a week or so and the same thing started again. I purchased a second cam sensor and again it was alright for a few days and gone again. The car starts right away but when I first start it it sputters and coughs all over the place, after it's running for a while it clears up and runs smoothly. (The cam sensors I purchased were from the Nissan dealership in my area). Thanks
KHLOW2008
  • 41,812 POSTS
What was the EXACT troube code retrieved?
  • 110,248 POSTS
If the timing belt is stretched, it could cause the sensors to misread what is going on.
SHANAV.
I had my distributor replaced and I'm not sure of the firing order of the wires. It is turning over but not starting. I think the problem may be the placement of the spark plug wires or the timing being off? Can anyone help me with a diagram of the firing order or can you tell me how to set the timing without a timing light, if possible? Thank you for any help you may be able to give me!
Sep 7, 2020 at 7:02 AM (Merged)
Good morning,
I attached pictures of setting the distributor in the correct way with the rotor.
make sure you have the engine at top dead center compression stroke. remove number 1 spark plug and hand crank the motor until you feel pressure coming out of the spark plug hole.
then match the pointer on the crank to 0 mark. then set the distributor as shown in the picture. the wires are also shown for the correct position.
The ignition timing is 0 degrees with a timing light.
The firing order is 1-3-4-2
HEATHER SUGGS
I need the firing order.
WRENCHTECH
  • 20,760 POSTS
Rotor turns counter clockwise. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Firing order 1-3-4-2.
SANDEE WON
  • 9 POSTS
The timing is out Where is the mark?
HMAC300
  • 48,601 POSTS
timing spec 10 degrees btdc 550-650 manual 575-675 auto. pics included. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
JGAT
What is the Firing Order for a 1994 Nissan Sentra? It has the 1.6L Engine, Manual Transmission, 160K Miles.
Thanks!
CHARLESDAV
If you are looking from the front of the car from left to right 1, 2, 3, 4 it should be on the distributor cap starting from top right plug and going clockwise 3 - 1 - 4 - 2, another web site has a differnt firing order showing 1 - 3 - 4 - 2 but I have the same engine and the first one I gave you is how my firing order is.
LADYAPPLE
Engine Performance problem
1987 Nissan Sentra 4 cyl Wheel Drive Type unknown Manual ? miles
How do I get the firing order to have the timing done on my car?
Sep 7, 2020 at 7:03 AM (Merged)
  • 75,988 POSTS
There you go
https://images.2carpros.com/forum/automotive_pictures/12900_fo3_1.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_fo_3.jpg
Good Luck
TIM LYON
while doing the tune up I have crossed some plug wires i need the firing order, the cap is marked
Jan 8, 2021 at 3:54 AM (Merged)
  • 75,988 POSTS
Merry Christmas see below
https://images.2carpros.com/forum/automotive_pictures/12900_FO_1.jpg
