1987 Nissan Sentra fuel gauge and temperature gauge
203,000 MILES • 4 CYL • 2WD • MANUAL
TIGHT2DEATH30
my fuel gauge or my temperature gauge is not working. it use to register occasionally and then go back down. i do have a electrical problem with my signal lights working occasionally. i was told the reason for my gauges was i need to replace my instrument panel.
Dec 30, 2009 at 1:51 PM
ZAOPC22
  • 9 POSTS
Well, I must say your car is a dinosaur but if you like it and you really want to spend the money then just go to Kragen and buy a gauge cluster with all 3 amps,oil,temp. and hire a mechanic to hook it all up for you. As for the turn signals or lights you might just run new wires with a new flasher, fuse, and an aftermarket switch and do it all from scratch. Or spend the time tracking loose connections and or disconnected or shorting or high resistance wires. Good luck David Newton please donate if this helped you out
Dec 30, 2009 at 2:07 PM
