Engine Mechanical problem
2004 Nissan Quest 6 cyl Four Wheel Drive Automatic
The engine won't turn over. What do you think could be the problem and do you think it will cost $3000? A mechanic said it was a sensor problem and then he said it was the timing belt. The final analysis was that it would cost $3000 to fix, which is so hard for me to believe!
Aug 30, 2010 at 8:48 AM
