2002 Nissan Quest shaking around 60 miles/ hour
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
DJOS76
when the quest start shaking I took to shop they change all the tie rod inner and outer also the joints ball and the 4 shock as well and the driver side cv joint since the grease was leaking but the quest still shaking when you push the gas around the 60 miles/hour what can be any idea, please
Jul 19, 2009 at 2:29 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Where do you feel this vibration, steering, body or both?
mark (mhpautos)
Jul 19, 2009 at 10:38 PM
DJOS76
the vibration feel in both (body and steering ) but is just when I push the gas pedal, example is I'm going down the hill fine when the car is in idle start shaking a soon y push the pedal gas, shaking around the 60- 65 mile per hour
Jul 20, 2009 at 2:05 AM
  • 31,937 POSTS
Hi there,
this is just something that will require close investigation, start with wheels & tyres, engine mounts, transmission mounts, alignment, sub frame is tight on the body, start here.
mark (mhpautos)
Jul 20, 2009 at 10:09 AM
