2002 Nissan Quest overheating
2002 NISSAN QUEST
11,900 MILES • 6 CYL • FWD • AUTOMATIC
DUDECHEVROLET
the temp gauge goes to hot after about 20 minutes then back to normal and back to hot over and over. the heat or air cond. only work when gauge is at normal. installed new t-stat and water pump. what do you suggest?
May 13, 2009 at 9:26 AM
Cooling fans are they coming on On time? If not check the coolant temperature sensor
Try bleeding the cooling system could be airlock and see what happens
May 13, 2009 at 10:19 PM
