2000 Nissan Quest wont start
14,400 MILES • 6 CYL • 2WD • AUTOMATIC
RS9696
my car started hesitaing like gas wasnt get to engine when i pressed gas was shaking and hesitating let off gas coasted a couple blocks then parked and then now it wont start back up think it is a fuel filter? or injectors? it was running fine i had oil changed 3 blocks later not working i know oil chnge shouldnt have anything to do w/fual
Jun 14, 2009 at 7:55 AM
  • 75,988 POSTS
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Jun 14, 2009 at 10:09 AM
