2000 Nissan Quest wont start
RS9696
  • 2000 NISSAN QUEST
  • 6 CYL
  • 14,400 MILES
My car started hesitaing like gas wasnt get to engine when I pressed gas was shaking and hesitating let off gas coasted a couple blocks then parked and then now it wont start back up think it is a fuel filter? Or injectors? It was running fine I had oil changed 3 blocks later not working I know oil chnge shouldnt have anything to do w/fual
Sunday, June 14th, 2009 AT 2:55 PM
Now it wont start back up think it is a fuel filter
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Sunday, June 14th, 2009 AT 5:09 PM
