2000 Nissan Quest
2000 NISSAN QUEST
QUEST2000
Shakes or Wobbles problem
2000 Nissan Quest 6 cyl Front Wheel Drive Automatic
I JUST HAD NEW AXLES BOTH LEFT AND RIGHT REPLACED ,BECAUSE THE CAR MADE CLICKING NOISE WHEN TURNING BUT THE CAR STILL SHAKESAT HIGH SPEED AND WABBLES AT LOW WHY?
Jan 28, 2009 at 4:40 AM
SCHRIMPIEMAN
  • 166 POSTS
Sounds like the tires need balancing.
Also, while the tires are being balanced, have the tech visually inspect the tire to make sure they are round/true. (They may not have high/low portions).
Also, make sure the rim(s) are not bent. Again, this is easiest to see while the wheel/tire is spinning on the balancing equipment.
Feb 17, 2009 at 12:49 PM
