1999 Nissan Quest replace radiator
1999 NISSAN QUEST
BUTCHIE56
1999 Nissan Quest 4 cyl Front Wheel Drive Automatic
how do i replace radiator
Nov 27, 2009 at 11:49 PM
https://images.2carpros.com/forum/automotive_pictures/12900_radiator_1.jpg
Remove under cover. Drain coolant from radiator. Disconnect radiator upper and lower hoses. Remove A/T oil cooler hoses. Disconnect reservoir tank hose. Remove right bolt from fuse box and position fuse box aside. Disconnect cooling fan harness connector. Remove radiator. After repairing or replacing radiator, install all parts in reverse order of removal. Fill radiator with engine coolant.
Nov 27, 2009 at 11:53 PM
