1999 Nissan Quest camshaft sensor position a bank one
JR1216
  • 6 POSTS
Engine Mechanical problem
1999 Nissan Quest 6 cyl Two Wheel Drive Automatic
i need to know where the this sensor is located in engine?
Oct 30, 2010 at 9:09 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the camshaft sensor is actually built into the distributor itself..
Oct 30, 2010 at 1:42 PM
JR1216
  • 6 POSTS
[quote:fe2840dda1="bluelightnin6"]the camshaft sensor is actually built into the distributor itself..[/quote:fe2840dda1]
i would also like to know why theres no current going into the sparks, the car wont start up
Oct 31, 2010 at 8:39 AM
BLUELIGHTNIN6
  • 16,542 POSTS
could be due to faulty distributor, is dist. getting power?
Oct 31, 2010 at 8:40 AM
JR1216
  • 6 POSTS
[quote:92c13b2318="bluelightnin6"]could be due to faulty distributor, is dist. getting power?[/quote:92c13b2318]
how do i check if the distributor is getting power?
Oct 31, 2010 at 8:42 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Did you check to see if you have spark at the end of the coil wire that plugs into the distributor? You'll need to go back to basic's. Check coil wire for spark. If yes, Are your plug wires installled in the right firing order? Is your distributor reinstalled at No. 1 at TDC and your rotor is sitting on No.1 firing order. Check to insure that your distributor wire harness is pluged in and making good contact. Post back your findings.
Oct 31, 2010 at 8:49 AM
JR1216
  • 6 POSTS
[quote:3576513c0f="bluelightnin6"]Did you check to see if you have spark at the end of the coil wire that plugs into the distributor? You'll need to go back to basic's. Check coil wire for spark. If yes, Are your plug wires installled in the right firing order? Is your distributor reinstalled at No. 1 at TDC and your rotor is sitting on No.1 firing order. Check to insure that your distributor wire harness is pluged in and making good contact. Post back your findings.[/quote:3576513c0f]
yes i check all of these already and still doesnt work, i took the cap off the distributor and theres seems to be no power
Oct 31, 2010 at 8:57 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if fuses and wiring good then dist. is most likely at fault
Oct 31, 2010 at 8:58 AM
JR1216
  • 6 POSTS
[quote:ed4f1df2aa="bluelightnin6"]if fuses and wiring good then dist. is most likely at fault[/quote:ed4f1df2aa]
where are the fuses located for the distributor ?
Oct 31, 2010 at 9:01 AM
BLUELIGHTNIN6
  • 16,542 POSTS
i can't seem to locate a fuse diagram for the vehicle so i'm not sure
Oct 31, 2010 at 9:02 AM
JR1216
  • 6 POSTS
[quote:d226bc7da2="bluelightnin6"]i can't seem to locate a fuse diagram for the vehicle so i'm not sure[/quote:d226bc7da2]
oh ok, well i replaced the distributor with another one i still keep getting the same code as the first and engine wont start
Oct 31, 2010 at 9:09 AM
