1999 Nissan Quest
DAVID LOFTEN
  • 7 POSTS
Brakes problem
1999 Nissan Quest 6 cyl Front Wheel Drive Automatic
left front brake lock up replace brake line & cal
Jul 26, 2010 at 6:49 AM
DOCFIXIT
  • 18,828 POSTS
Hi
What's your question? is it after replacing parts wheel is still locked?
Let me know
Jul 26, 2010 at 7:02 AM
DAVID LOFTEN
  • 7 POSTS
yes left front lock up replace cal still lock up went one pump of the brake lock up so though cal was bad replace again still lock up . was told that the brake line could be bad so replace it . still the same also was told that the right rear brake line could be bad replace it still the same
Jul 26, 2010 at 7:32 AM
DAVID LOFTEN
  • 7 POSTS
this 1999 nissan quest has ABS
Jul 26, 2010 at 7:54 AM
DAVID LOFTEN
  • 7 POSTS
do you have a anwser do i need to changer the ABS system or the master cycler
Jul 26, 2010 at 8:08 AM
DAVID LOFTEN
  • 7 POSTS
do i need to donate again to get the anwser
Jul 26, 2010 at 8:24 AM
DOCFIXIT
  • 18,828 POSTS
When caliper is locked open bleeder does fluid squirt out? also did pins get cleaned and lubed? see diagram
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_528.jpg
Jul 27, 2010 at 5:19 AM
