1998 Nissan Quest water pump
RAMOOSCA
  • 1998 NISSAN QUEST
  • 6 CYL
  • 180,000 MILES
Do I need to take the whole engine down in order to replace the water pump?
Wednesday, May 26th, 2010 AT 1:24 PM
OBXAUTOMEDIC
  • 3,711 POSTS
You will need to remove the timing cover in order to get to the rest of the water pump bolts. So, you will pretty much have to take the front of the motor off.
And I would Highly Recommend changing the Timing Components at the same time unless they have been done recently(20 - 30k miles).
I recommend it for the fact that you are already there and it is more cost effective to do both while there.
Wednesday, May 26th, 2010 AT 1:37 PM
