1997 Nissan Quest transmission fluid.
CALISK8ER1600
Transmission problem
1997 Nissan Quest 6 cyl Front Wheel Drive Automatic
I'm changing the transmission fluid pan on my 97 nissan quest and i cant find anywhere (including the manual) how much fluid im supposed to put into it when im done. can anyone help?
oh i forgot to mention the reason im changing the pan is because i hit a curb, punched a hole in the pan, and have no fluid at all now.
Dec 26, 2009 at 3:28 PM
  • 75,988 POSTS
You have a total of 9.9 qts including the torque converter. when you change the filter replace the amount that was drained then check the level again might need more or less.
Dec 26, 2009 at 3:40 PM
