1997 Nissan Quest need to know how
WHITTINGTON0
Engine Cooling problem
1997 Nissan Quest 6 cyl Front Wheel Drive Automatic
Greetings,
I'm trying to replace my Thermostat and have run into a problem. I have the housing disconnected but there is a metal plate keeping me from being able to pull it out.
Feb 26, 2010 at 8:17 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for the donation The thermostat is located in the thermostat housing, which is mounted to the coolant crossover tube. The bypass hose is connected to the thermostat water inlet on one end, and to the intake manifold water outlet on the other. REMOVAL & INSTALLATION Drain the radiator and recycle the engine coolant. Remove the upper radiator hose bracket bolt and remove the bracket. On 1993-98 3.0L engine models: Remove the bolt from the A/C high pressure line bracket at the front of the engine. Remove the two A/C accumulator/drier bracket bolts. Position the accumulator/drier and A/C line out of the way. Remove the bypass hose clamp and remove the hose from the water inlet. Remove the four water inlet bolts and remove the inlet. Remove the thermostat from the inlet.
https://images.2carpros.com/forum/automotive_pictures/261618_1_134.jpg
To install: Clean and dry the water inlet and thermostat housing mating surfaces. Apply a continuous bead of RTV silicone sealant 0.08-0.12 inch (2.0-3.0mm) wide to the water inlet mating surface. NOTE The water inlet must be installed within 5 minutes of applying the sealant. Install the thermostat in the water inlet, with the jiggle valve at the topmost (12 o'clock) position. Install the water inlet to the thermostat housing. Install the bolts and tighten them to 12-15 ft. lbs. (16-21 Nm). Install the bypass hose to the water inlet, using a new clamp. On 1993-98 3.0L engine models: Install the accumulator/drier and tighten the bracket bolts to 45 inch lbs. (5 Nm). Install the A/C high pressure line bracket and tighten the bolt to 45 inch lbs. (5 Nm). Install the upper radiator hose bracket and tighten the bolt to 34-48 ft. lbs. (46-65 Nm). NOTE Allow the sealant to dry for at least 30 minutes before adding coolant. Fill the cooling system. Run the engine and check for leaks.
Feb 26, 2010 at 8:27 AM
