I disconected negative baterry cable and then waited a minute or so and reconnected it.When I tried to start car again(which ,before disconecting negative battery cable would turn over,with compresion,but not start)the indicators on the dash lit up as normal and then went dead.I tried turning the ignition (key) again and the same happened again.I then disconected negative battery cable once again and reconnected.When i tried turning on the key again nothing happened at all.I rechecked the battery cable and all looks as it should.How to I go about trouble shooting this problem?
Sep 4, 2009 at 9:59 AM
