1995 Nissan Quest Neutral Safety Switch
134,000 MILES • 6 CYL • FWD • AUTOMATIC
BIG1KAHUNA
My unerstanding is that I need to replace the neutral switch -- the van won't start in park, however, we've been able to bypass that by keeping it in neutral to start. This no longer works. I've replaced the starter, battery, plugs & wires in the last year & a half; I also just replaced the ignition coil.
My question is -- where do I find the neutral switch? I've been told it's on the trans(mission?...fer?) case.
Mar 19, 2009 at 12:32 AM
  • 75,988 POSTS
Check fuseZ 10amp, the inhibitor switch is on the transmission and the inhibitor relay left front of engine compartment
Mar 19, 2009 at 9:22 AM
