1995 Nissan Quest Engine hard to start.
1995 NISSAN QUEST
JMATEEN1
Smells problem
1995 Nissan Quest 6 cyl Front Wheel Drive Automatic
I own a 95 Nissan Quest minvan. It start up when it is cold but after I run it for an hour or os and turn it off I smell gas fumes. I have replaced the MAF sensor,spark plugs.
Jul 29, 2009 at 9:03 AM
Running too rich
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Jul 29, 2009 at 9:55 PM
