i have a nissan qiest a it wont crank over i put a new timing belt also has a new battery please help
Feb 19, 2009 at 9:44 AM
✓Experienced Mechanic
Did you double check the valve and ignition timing when you installed the T-Belt.
Feb 19, 2009 at 10:05 AM
QUESTER209
MEMBER
1 POST
yes it was running good since tha problem i let friend use it and he call me that it wonk crank over could it be the head gasket
Feb 20, 2009 at 9:21 AM
Remove all sparkplugs and crank engine over do you see coolant spewing out
Feb 20, 2009 at 10:11 AM
