1988 Nissan Pulsar Not turning over, no clicking, power to
1988 NISSAN PULSAR
168,000 MILES • 4 CYL • FWD • MANUAL
GHOSTLOGIC360
I have a 1988 Nissan Pulsar NX SE that refuses to start. It was running great, I parked it for two minutes and it didnt start back up. I have full lights inside and out. I can hear the fuel pump cutting on when I turn the key but there is no clicking, very little headlight dimming, and no attempt to turn over. I can start it by "rolling start."
Any ideas?
May 27, 2010 at 7:55 AM
Possibilities here could be battery connections, starter, starter interlock relay, clutch switch and ignition switch
May 27, 2010 at 9:55 AM
CHOOKIE 2012
We just had exactly the same problem last week with our holden astra 1988. Same car apparently. It was the Altinator wire that was loose and wasnt charging the battery. Check your wires make sure that they are all connected to the fuse box and that nothing is loose. Good luck
Jul 28, 2012 at 11:59 PM
