1988 Nissan Pulsar brakes
1988 NISSAN PULSAR
FATTYHARRO
Brakes problem
1988 Nissan Pulsar 4 cyl Front Wheel Drive Manual
on the dash ive got the brake light on. ive checked brake fluid and that seems okay,.i cant find the problem but when i put foot on brakes the pedal reaches the floor if i leave foot on it
Jun 2, 2010 at 4:09 PM
Check if its leaking somewhere front and back if not the problem here could be the brake master cylinder leaking internally due to seals/cups-wear and tear
Jun 2, 2010 at 9:04 PM
  • 31,937 POSTS
Hi There, the brake pressure switch has tripped, if you have no fluid loss, the master cylinder will be faulty, have it replaced and get the full brake system re bleed.
mark (mhpautos)
Jun 2, 2010 at 9:09 PM
