1988 Nissan Pulsar
1988 NISSAN PULSAR
LENNARD
1988 Nissan Pulsar 4 cyl Two Wheel Drive Manual
Car runs for 5-10 min then stops. wait an hour or so and will restart and run for 5-10 min again. Have changed the fuel filter, fuel pump sounds good. Help!!!!
Dec 24, 2009 at 10:18 PM
  • CAR REPAIR CONTRIBUTOR
Next time when it won't start don't wait for nothing to catch it-Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard.
Dec 26, 2009 at 5:26 AM
