1993 Nissan Primera nissan primera
1993 NISSAN PRIMERA
300,770 MILES • 4 CYL • FWD • AUTOMATIC
DION COLLIE
Hi
I have a 93 primera starts normally when cold soon as it gets hot fuel seems to richen has been put on computer and will not allow scan for error codes
Mar 23, 2010 at 5:15 PM
Probable causes of an engine running rich are as follows:
1.Fuel pressure not within specs.Can be cause by restricted fuel return line or defective fuel pressure regulator.
2.Defective Oxygen Sensors.
3.Leaking injectors.
4.Coolant temperature sensor out of calibration.
5.Restricted air intake system.
Mar 23, 2010 at 6:03 PM
DION COLLIE
[quote:3c925473df="Dion Collie"]Engine Performance problem
1993 Nissan Primera 4 cyl Front Wheel Drive Automatic 300770 miles
Hi
I have a 93 primera starts normally when cold soon as it gets hot fuel seems to richen has been put on computer and will not allow scan for error codes[/quote:3c925473df]
Hi thanks for that
I have managed to dwnload a p10 manual
Have had another look at the problems and
The engine check light is NOT on.
have done checks the book specifies they seem to check out (egr etc:
engine seems to gradually start hunting and tries to leap forward.
Have also checked air cleaner
vaccume lines for leaks
One thing I have not checked is the 02 sensor
All of the checks have been done manually
Mar 25, 2010 at 8:02 PM
