1999 Nissan Patrol/Safari fuel tank
1999 NISSAN PATROL/SAFARI
189,000 MILES • 6 CYL • 4WD • AUTOMATIC
TAMAR69JUSTIN
Hi i was transferring some unleaded fuel from one car to another using the plastic pump and when it came time to pull the pump out it got stuck and my partner tried to pull the bit off plastic out that had got stuck but a small amount fell in to the tank and we are both sooooo scared that something bad will happen we dont know what to do and we are just woundering if someone could please lat us know what to do and if this is major thanks just so scared.
Aug 8, 2010 at 9:12 AM
IORKAMAVE
  • 7 POSTS
The bit of plastic in the tank will not harm your car. The fuel intake pipe in the tank has a filter that will prevent the plastic from getting into the fuel line. If you are still scared, you can bring down and clean inside the tank.
Sep 16, 2010 at 4:01 AM
