1995 Nissan Pathfinder Fuel Tank Leak
SGLISBY
My daughter has a 1995 Nissam Pathfinder with 109XXX miles. Recently, she began noticing a fuel leak around the rear of the vehicle. When she came home last weekend, we saw a large leak. I dropped the tank as far as possible (receiver hitch in the way) and found it was leaking around the fuel pump. The fuel line was so rusted it broke near the top of the fuel pump mounting plate on top of the tank. Bought a used one and still can't get a seal on the tank. Fuel still leaks around the fuel pump plate. O-ring seems to be in good shape. Top of tank rusted. Any ideas?
Nov 28, 2006 at 1:40 PM
MIKEYBDMAN
  • 623 POSTS
[quote:dec57c5257="addhead14"]Hello,
I have an 1995 Integra GSR with 123,000 miles. This car has been great and I am very diligent with getting it serviced. However, I am having issues with the ABS light. It comes on after I have been driving about a mile and stays on.
So far, I have had the rear caliphers and the ABS relay replaced. According to my mechanic, the ABS memory displays a code of 4-8. The left rear speed sensor was replaced and the light still comes on. There are no other apparent braking or electrical problems.
What should I be checking next? I will take any suggestions at this point. I have had my car at the mechanic four times for this problem.
Thank you very much.[/quote:dec57c5257]
Well, the 4-8 code indicates a problem with the left rear wheel sensor circuit. If the sensor was replaced, and no help. Then it can be the wiring, a problem with the pulser, modulator, or the ABS controller itself. You are just going to have to get a mechanic to track down the problem and correct it.
I would start by checking the entire wiring harness for any kind of chaffing, or wear. Even pull and tug a little to see if you can find if there is a problem. I would check the connectors and make sure the signals are properly being transfered.
It could be the controller, but that is a very expensive "lets try this" attempt.
Good luck on fixing this....and let us know what did it.
Jul 17, 2006 at 10:48 AM
ADDHEAD14
I am curious about how much an ABS controller costs.
However, I am hoping that it the wiring. The wiring could be an issue as I also just replaced a relay switch.
Thanks for your input.
Jul 21, 2006 at 3:04 AM
SENSE-A
sometimes my ABS light comes on. But i don't even care, my regular brakes work fine. A lot of cars don't even have abs brakes. Matter of fact I don't neccesarily like ABS brakes so just learn to not give a sh*t if thats all thats wrong with your car. as long as you're not leaking brake fluid and you have good pads you're fine.
Aug 7, 2006 at 8:10 AM
ADDHEAD14
After a few more examinations of my car, the ABS light is now fixed. It ended up being both rear sensors that had to be replaced.
I do like having ABS brakes. I live in New Hampshire and travel some steep rural roads in the winter time. They have saved me from going off the road during a snow storm.
Aug 22, 2006 at 6:23 AM
  • 55,682 POSTS
All sealing surfaces need to clean and free of rust, always use new seals. Let me know :D
Nov 29, 2006 at 4:30 AM
Suggested Repair
Clean all fuel-pump mounting-plate sealing surfaces until they are free of rust, and always install new seals or O-rings before resealing the tank.
Conversation Summary
The owner of a 1995 Nissan Pathfinder reported a rear fuel leak. After lowering the tank, the leak was found around the fuel pump; a rusted fuel line broke near the pump mounting plate, and a used replacement still leaked despite an apparently good O-ring. The top of the tank was rusted. An expert advised cleaning all sealing surfaces free of rust and always using new seals. Other replies discussed an unrelated ABS warning-light issue on a different vehicle.
