99 pathfinder - obd 2 code reader information
PATHFINDERRS
  • 8 POSTS
hello, this site is great!
What does it mean after hooking up a code reader when the Freeze Frame section says:
Fuel Sys 1 - OL, not ready CL
Fuel Sys 2 - OL, not ready CL
MAP 29, 2
and the I/M Status (what does I/M stand for?) says:
EVAP System mon inc
Oxygen Sensor mon inc
Oxygen Sensor Htr inc
EGR system inc
I presume the inc means incomplete..but why? do I need to turn the engine on..running for this section?
thanks
Jun 8, 2007 at 12:42 PM
BACKYARDMECHANIC
  • 337 POSTS
Sounds like the battery was disconnected and the car needs to run through a drive cycle. Each car is different so some will cycle sooner then others. Drive the car around for awhile and then run a scan on it again. If the car was driven long enough then you shouldn't get a inc or not ready.
Jun 8, 2007 at 12:54 PM
