2007 Nissan Pathfinder Windshield Washer Leaking
SCEZLIVIN
Electrical problem
2007 Nissan Pathfinder 4 cyl Two Wheel Drive Automatic
Add windshield washer fluid and after a few minutes it all ran out through the fender. The bottle seems to be between the fender and a piece of metal in the engine compartment. The only part i can seem to access is the top of the fluid bottle. I really think that the hose might have come lose from the bottom of the bottle. How do I access the bottom of the bottle
Jul 14, 2010 at 4:28 PM
BLUELIGHTNIN6
  • 16,542 POSTS
There is a technical service bulletion (TSB) about the issue of leaking washer fluid on this vehicle. The issue is that the grommet seal on the reservoir filler neck becomes unable to hold the fluid and allows it to leak out. There is a new grommet that should be replaced , the part number for it is 28982-ZP00A . This is probably where your fluid is leaking from as well. .
Aug 19, 2010 at 9:22 AM
