It seems that my factory installed trailing wiring 4 plug harness is not sending a signal to my right turn signal. I put a tester on the end of the 4 plug and I am able to have the left and parking lights light up on the tester. For the right turn signal I am not able to get a light showing up on the tester. I have checked all the fuses which are all fine.
I have traced the wiring to an extent but I think that my BCM may not be sending a singal out. Is there any way to test this from the BCM and is there another alternative to connect a new 4 plug wiring harness so that I can get left, right and parking lights to work?
I look forward to your response.
Jul 9, 2009 at 1:08 AM
