How do I remove the brake rotors on my 2005 Nissan Pathfinder?
Feb 26, 2010 at 11:17 AM
BLUELIGHTNIN6
✓Experienced Mechanic
Front Brake Rotor Removal
Raise and safely support the vehicle.
Remove the wheel and tire assembly.
Remove the caliper and suspend it aside with a piece of wire. Do NOT disconnect the fluid line.
Slide the rotor off.
Installation is the reverse of the removal procedure.
