Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Pathfinder
Fuel System
Fuel Level Sensor
2005 Nissan Pathfinder
2005 NISSAN PATHFINDER
BHEESHAM1
MEMBER
1 POST
2005 Nissan Pathfinder 6 cyl Four Wheel Drive Automatic
how to repair the fuel level sender
Jan 17, 2010 at 12:50 AM
OBXAUTOMEDIC
Experienced Mechanic
In order to replace the Sending unit you will have to drop the gas tank. The sending unit is in the tank and the fuel pump is attached to it.
Would recommend replacing fuel pump also since have to remove it to change sending unit.
Jan 17, 2010 at 2:11 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine has low power
