2004 Nissan Pathfinder oil meter
10,014 MILES • 6 CYL • 2WD • AUTOMATIC
EDITHMARIE6
were looking to buying a 2004 nissan pathfinder the only problem that we see is that the oil meter is all the way to the top. the car is running well. is this a big problem what could be wrong with it.
Mar 2, 2010 at 8:11 AM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge,if normal replace the oil pressure switch.If abnormal could mean oil pump and engine bearing.
Mar 2, 2010 at 8:18 AM
