2002 Nissan Pathfinder Now Fan
135,000 MILES • 6 CYL • 4WD • AUTOMATIC
SIMPLECOMPLEX
My girlfriend came home today and said there was no heat in her pathfinder. I checked it out and there was no fan. I checked both blower fuses and hotwired the blower relay and still nothing. I think I hear the fan turning slowly when the heat is on but if it is, it's not fast enough to throw out any heat. There's also no change when I remove the fuses or the relay. What's the next check?
Jan 10, 2008 at 12:04 PM
FISHERMAN
  • 937 POSTS
[quote:026e7f8d0b="Simplecomplex"]Heater problem
2002 Nissan Pathfinder 6 cyl Four Wheel Drive Automatic 135000 miles
My girlfriend came home today and said there was no heat in her pathfinder. I checked it out and there was no fan. I checked both blower fuses and hotwired the blower relay and still nothing. I think I hear the fan turning slowly when the heat is on but if it is, it's not fast enough to throw out any heat. There's also no change when I remove the fuses or the relay. What's the next check?[/quote:026e7f8d0b]
Hello !!
Check the blower resistor and replace it if faulty.
good luck!
Jan 10, 2008 at 12:26 PM
FISHERMAN
  • 937 POSTS
Also check the power going to the resistor It`s not working at any speed? here`s a picture of the blower and resistor:
https://images.2carpros.com/forum/automotive_pictures/576_0000_1.jpg
good Luck!
Jan 10, 2008 at 12:32 PM
SIMPLECOMPLEX
No, The fan's not working at any speed.
How do I test the resistor? Do I just test for 12 volts between the contacts?
Thanks for your help.
Jan 10, 2008 at 1:00 PM
FISHERMAN
  • 937 POSTS
Hello Again.. CHECK POWER SUPPLY FOR BLOWER MOTOR 1. Disconnect blower motor harness connector. 2. Do approx. 12 volts exist between blower motor harness terminal No. 1 and body ground? here`s how:
https://images.2carpros.com/forum/automotive_pictures/576_00_2.jpg
Good Luck!
Jan 10, 2008 at 2:23 PM
