2000 Pathfinder Front Suspension noise
BRAULIO
Hello:
I have a 2000 Pathfinder 2WD 3.3motor with at least 90K miles. Almost 1 1/2 years ago a rattling noise started coming out of the fron t end of the vehicle. My mechanic suggested to replace the link bars of both left and right sides which i did and the noise was gone. No more than 5 months later the same noise came again and yet again the link bars were replaced and the noise was gone. After at least 6 mohts after the second link changed the noise came back this time only from the right side. That time i only replaced the right link with a Original Nissan Link instead of a replacement brand, the noise was gone. Now the noise is back again, this time from the left side, and yes it is the same noise. I dont know what to do becasue if something else i dont know is wrong i'll be replacing links all my life. I was wondering if you can assist me with my concern.
Thanks
Braulio
May 23, 2007 at 3:49 PM
DATSUNRAISED
  • 37 POSTS
That sounds like very unnatural wear. Have you had the alignment checked after replacement? They might find an issue with the ball joints.
Jun 2, 2007 at 3:50 AM
BRAULIO
Will do and will let know the results..thanks for the suggestion I was looking forward for one..
Jun 3, 2007 at 2:38 PM
