2000 Nissan Pathfinder Speedometer, Tachometer, Engine Temp
10,600 MILES • 4 CYL • 2WD • AUTOMATIC
MLAURIN01
The three meters or gauges above will often just stop working and go down to zero - now sometimes the speedometer sticks on a mph like 80. I am about to bring to the dealership and would like to be somewhat knowledgable on what is happening. I know nothing about cars. Thank you for your assistance.
Jul 29, 2009 at 2:14 AM
BUDDYCRAIGG
  • 2,262 POSTS
That will most likely be a "cold solder" joint on the circuit board in the gauge cluster, or a bad connection where the wires plug in to the cluster.
Jul 29, 2009 at 2:43 AM
DOCFIXIT
  • 18,828 POSTS
Hi ,Maybe the printed circuit board in instrument cluster or the wire connector to circuit board. Probably need to pull out cluster and make some tests.
Hope this helps
Thanks for donate
BUDDYCRAIGG
  • 2,262 POSTS
I beat ya doc.
Jul 29, 2009 at 3:39 AM
GHOSTOFANAMELESSMAN
I had the same problem with mine some time ago. Replacing the instrument cluster altogether is what solved the problem for me.
Nov 23, 2009 at 7:19 PM
