1988 Nissan Pathfinder gas guage
1988 NISSAN PATHFINDER
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
ROBERTFGM
what can stop the gas guage from working i have replaced the fuel sending unit
Apr 23, 2010 at 6:13 PM
CWBY37
It could be a couple things. The float could be sticking, you could have a wire grounding, especially with an older vehicle. On the first you would have to pull the mechanism out of the tank. On the second, they have an electrical tester that you could hook up to the sending unit side and on the gauge side which should tell you if you have a break, ground, etc.
Apr 24, 2010 at 10:43 AM
