2000 Nissan Pathfinder Power steering belt keeps breaking!
2000 NISSAN PATHFINDER
80,000 MILES • 6 CYL • 4WD • AUTOMATIC
DHJONES
My daughter has a 2000 Nissan Pathfinder. About a week ago, the power steering went out. I got a look at it and the PS belt was really loose. I decided to change it.
Let me give you a mental picture of the Pathfinder engine compartment. It's ,of course a V-6. There are 3 belts. From front to back: 1) there's a serpentine belt that runs - I think - just the A/C. 2) Then another serpentine belt behind that which runs the alternator (what? and maybe the water pump?). 3) Then (closest to the engine block) is a fairly short, old-fashioned V-belt which goes only to the power steering.
Okay, so I monkeyed around and finally maneuvered the two serpentine belts, and installed a new V-belt on the PS. Everything worked great. Then after about two days, the V-belt broke. Again no PS. I asked a guy at church and he said I probably tightened the V-belt too much.
So I installed another V-belt for the PS. This time I was more careful (I thought) not to overtighten the PS belt. Again, it lasted about 2 days. This morning my daughter was backing out of the driveway and the belt broke...and while it did that, it knocked one of the serpentine belts loose.
So here's the dilemma: I'm going through PS belts like crazy. Why? Right after the belt broke this morning I turned the pulley on the PS pump. It would turn easily (I thought maybe the pump was seizing up or something... and causing belt failure.) Go any ideas? Thank goodness the belts are less than ten bucks! But 2 days to a belt is getting a little expensive!
HELP! I'm at a loss!
Aug 14, 2008 at 11:29 AM
SERVICE WRITER
  • 9,123 POSTS
Two reasons a good belt brakes with proper tension generally are a pulley seizing or misalignment. Look for tell tale signs. Immediatly check the pullies it runs on after it brakes for a seized pulley. Temperature can allow a pulley return to a free state when it cools. Litle rubber dust particles may show on pulley area also. Alignment issues usually will show a glazing on the v-edges. Mis alignment is sometimes visable to the eye as the belt looks out of kilt when installed. Another form of mis alignment is within the belt to pulley fit. IF you take the belt and place it in the groove of the pulley it should fit properly. It should fit like this:
https://images.2carpros.com/forum/automotive_pictures/30961_mufp_0711_02_zengine_belt_fit_and_alignmentbelt_diagram_1.jpg
Nice and flush on the mating surfaces. Some aftermarket belts can be problems and the fix is a dealer belt.
Aug 15, 2008 at 5:54 AM
